mgdurand1
May 05, 2019Luminary
Using just Armor with Norton installed
Hi again. I asked this quesiton this weekend and the answer really did not answer the quesiton I posed. The topic was immediately closed so I could not post this there. My question was as follows:...
Orbi-Roc
May 06, 2019Luminary
Hi mgdurand1 . I raised a similar question a few days ago and never got a response either. Although I was not dealing with Norton AV bur rather Defender on WIN 10 desktop and laptop; and ClamXAV on two MacBook Pros. I don't have Armor installed yet on my router, as I am still debating and reading on it. I have yet to find a good, reliable, review on Netgear Armor and hands-on test and performance assessment.
The fact the a Netgear moderator did not chime in to answer my question is probably the main reason I didn't jumb on the band wagon and activated the trial.
- DexterJBMay 08, 2019NETGEAR Moderator
Hi mgdurand1, I believe I've responded to one of your first post and sorry if I was not able to make it clear. As I've also informed Orbi-Roc, yes, you can run Armor alongside your already installed AV's since Armor is doing the check on the router side.
Dexter
- mgdurand1May 11, 2019Luminary
Thanks. I was unclear as to the repsonse. Likely my fault and I apologize. Happy that I can pay for Armor and not install Bitdefender software. Sure that is great AV software, but my set (Norton and Malwarebytes) has kept us safe for so long I am hesitant to change it. Thanks again!
- DexterJBMay 12, 2019NETGEAR Moderator
You're welcome! :D
