ynet's avatar
ynet
Using Netgear Armor with Xfinity Modem/Router
Hello,
I have a subscription for the Netgear Armor. Now I live in the condo that provides
Xfinity WiFi modem/router. So, I don't need my Netgear router anymore.
How can I use the Armor with the Xfinity WiFi modem/router?
I still have 180 days of subscription and want to use them.
Thank you,
  • The only way to do so would be to connect the netgear router to the xfi box and use the netgear router.
    To prevent a double nat (and still use armor) you'd either put the xfi box in passthrough/modem only mode or you'd put the netgears IP address into the xfi's DMZ.
  • plemans's avatar
    • ynet's avatar
      ynet
      Thank you very much for your recomendation.
