gdborch
Apr 20, 2019Guide
V1.3.1.64_10.1.36 firmware update
after the firmware upgrade i can no longer access Armor through the web portal.Clicking on the Armor option provides a message that i am not subscribed. The nighthawk app, and bitdefender itself, says that i am subscribed and that Armor is active. It looks like the firmware upgrade was meant to enable new armor features but the current situation is just confusing . has anyone solved this?
- DexterJBNETGEAR Moderator
- gdborchGuide
as others have said resetting doesnt fix it.
it has now caused me to give up armor completely and find another solution. its not really acceptable for a security solution to fail on a firmware upgrade and have Netgear not take any action or show any concern about it. The whole netgear/armor experience has been very dissapointing. Bitdefender is good and working well for me and their support is excellent. The router part of netgear is fine and works well but the armor approach lacks many features of the bitdefender box2 offering and has very poor support except where bitdefender themselves are trying to help out. the armor subscription payment has been a waste of money for me. Now using the bitdefender box2 and bidefender central which is much, much better. Yes, some features of the netgear router are not available in AP mode but they are either features that i dont need or can be achieved in another way. interestingly one of the vulnerabilities in my network that bitdefender identifies is the R7000P router itself (insecure authentication procedure). Armor is a great idea from Netgear but it, and security in general, needs to be taken much more seriously by them if it is to be a good solution.
