zolicentrale
Jan 03, 2025Follower
VPN Installation
How to install VPN on Alexa cube or Roku tv ?
You'd want to look up for those specific devices how to add/use a vpn with them.
- JWS9518Luminary
Roku's tend to not play nice with VPN's. Roku tries to prevent VPN use as some apps will not work with VPNs on.
- JamesBaronAspirant
You can use a VPN with Roku by installing it on your router or using Smart DNS.
- JWS9518Luminary
JamesBaron Yes, that is true, however, some apps may not work correctly with a VPN installed. So, your mileage may vary in terms of successfully using a VPN with Roku.
