Surffa
Jul 08, 2019Apprentice
Vulnerability scan triggers HP printer to print pages
Hi all. It appears that the Armor vulnerability scan always causes my HP Laser printer to print three pages, containing a client version or similar. E.g. curl and version number or so. I'm quite s...
- Jun 18, 2020Now I have been running 2.5.1.16 for quite some time and so far not a single page has been printed out.
So perhaps this update finally fixed the issue.
Finally. Thanks.
schumaku
Jul 08, 2019Guru - Experienced User
Part of the vulnerability checks (not limitet to Armor) is sending some test data to the ports to be tested - if these are printer ports, this can lead to some garbage on the printer paper.
What would you expect as a solution?
