Surffa
Jul 08, 2019Apprentice
Vulnerability scan triggers HP printer to print pages
Hi all. It appears that the Armor vulnerability scan always causes my HP Laser printer to print three pages, containing a client version or similar. E.g. curl and version number or so. I'm quite s...
- Jun 18, 2020Now I have been running 2.5.1.16 for quite some time and so far not a single page has been printed out.
So perhaps this update finally fixed the issue.
Finally. Thanks.
HazardousTim
Sep 28, 2019Star
I have a Samsung Multifunctional printer and I also have the same issue occuring. My printer is kept on all the time but goes into a low power mode after not in use for a while.
This has to be something that can be changed in a future firmware or software update. Shouldn't be to difficult to come up with a solution I would think.
- SurffaSep 28, 2019ApprenticeMeanwhile I googled around and it seems to be a common symptom with different network printer and vulnerability scanners. Annoying anyway and should be solvable somehow..
I also got a contact to Bitdefender support and they at least told me they would look at the matter. Which now reminds me that I've forgotten to give them dumps that they requested.. *sigh*- tolidanoDec 04, 2019Aspirant
This also happened to me when I set up my 3-pack Orbi yesterday.
Needless to say, my first concern was if someone had gotten into my network.
If this is going to happen with Armor, how about you say something to that effect ahead of time.
Go ahead and tell your customers, "your printer might print garbage, don't worry, it's fine"
And when you realize how silly that is, you will think, "maybe we should fix the problem"
You have the MAC address, you can easily determine it is a printer.
You can then skip sending traffic to the RTSP port (9100).
