Surffa
Jul 08, 2019Apprentice
Vulnerability scan triggers HP printer to print pages
Hi all. It appears that the Armor vulnerability scan always causes my HP Laser printer to print three pages, containing a client version or similar. E.g. curl and version number or so. I'm quite s...
- Jun 18, 2020Now I have been running 2.5.1.16 for quite some time and so far not a single page has been printed out.
So perhaps this update finally fixed the issue.
Finally. Thanks.
DexterJB
Dec 05, 2019NETGEAR Moderator
Hi tolidano, the fix for the issue is currently under testing. We will provide an update once available.
Dexter
DexterJB
Dec 10, 2019NETGEAR Moderator
Hi tolidano, as a temporary fix, you can remove the printers from being scanned by Armor. You can do that by logging in to armor.netgear.com and clicking on the router > click on "See all devices on this router" > look for the device/s (printer) that you want to remove > click on the ellipsis (three dots) on the far right > click on Remove.
Dexter
- Eg2020Dec 10, 2019Tutor
Hi Dexter - Unfortunately this fix is too temporary. After a couple of hours the removed printer is automatically restored.
DexterJB wrote:Hi tolidano, as a temporary fix, you can remove the printers from being scanned by Armor. You can do that by logging in to armor.netgear.com and clicking on the router > click on "See all devices on this router" > look for the device/s (printer) that you want to remove > click on the ellipsis (three dots) on the far right > click on Remove.
Dexter
- Adrian97cDec 30, 2019Apprentice
Hello,
this is waisting my printer ink & paper!
any updates on netgear fixing this?!
- sendit_y0daDec 31, 2019AspirantI haven’t seen any update and won’t be subscribing to this Armor service after the 30 day free trial ends on 3rd January. I haven’t found it that useful and the unwanted printing issue is annoying.
- tolidanoDec 31, 2019AspirantI also think it is responsible for flickering (and ultimately bricking) one of my LIFX Color 1000 bulbs. And any other WiFi connected lights.
