Surffa
Jul 08, 2019Apprentice
Vulnerability scan triggers HP printer to print pages
Hi all. It appears that the Armor vulnerability scan always causes my HP Laser printer to print three pages, containing a client version or similar. E.g. curl and version number or so. I'm quite s...
- Jun 18, 2020Now I have been running 2.5.1.16 for quite some time and so far not a single page has been printed out.
So perhaps this update finally fixed the issue.
Finally. Thanks.
CVGRich
Apr 05, 2020Aspirant
I had the same issue. NG advised to update the firmware. That did not fix the problem.
They then advised me to do a factory reset on the router (which now had the updated firmware).
That stopped the problem.
Hope it works for you.
Adrian97c
Apr 06, 2020Apprentice
I did reset (which turned out to be a nightmare) but let’s see if this helps. On a side note, coincidently this morning the tech working on my case emailed me saying that the NEW FW will be out in may.
