Surffa
Jul 08, 2019Apprentice
Vulnerability scan triggers HP printer to print pages
Hi all. It appears that the Armor vulnerability scan always causes my HP Laser printer to print three pages, containing a client version or similar. E.g. curl and version number or so. I'm quite s...
- Jun 18, 2020Now I have been running 2.5.1.16 for quite some time and so far not a single page has been printed out.
So perhaps this update finally fixed the issue.
Finally. Thanks.
Surffa
Apr 05, 2020Apprentice
Adrian97c that's curious, as my RBR20 has now been running .30 SW for 1,5 weeks now.
Assuming the old schedule, it should've been printing twice, which it hasn't.
Printer still seems to work, so I have sort of a feeling that for my HP, which I originally reported the problem with, is now somehow in order with the Armor.
Surffa
Apr 11, 2020Apprentice
All right. So now after quite some time the printer printed out the garbage pages again. So I now switched the printer off again and let's see about the next FW update again.
So definitely this is still not fixed.
Why the behavior is not consistent every week is strange, did the vulnerability scan interval change, or is the Armor behavior simply no longer consistent.
- Corbetw1May 17, 2020AspirantAny solutions to this. I have an Orbi system with armor, fully activated, updated drivers, and I have 2 different HP printers printing the same 3 pages every single night.
- JBDJrMay 17, 2020Aspirant
I turned Armor off. Solved. I don't print three pages every week. I won't renew
Corbetw1 wrote:
Any solutions to this. I have an Orbi system with armor, fully activated, updated drivers, and I have 2 different HP printers printing the same 3 pages every single night.- SurffaMay 17, 2020ApprenticeYeah. Sure. No one needs a security solution before it's too late. For me this deal is still just a no-brainer. Even without network level protection there is no better deal for such a well reputed product anywhere.
Anyway. Looking back a few posts, at this point only reasonable recommendation is to be patient for a while. We know already that Bitdefender has already implemented a real solution and Netgear is integrating it. Sure it has taken frustratingly long, but all the signs are pointing to that it could appear soonish. If it then even works, remains to be seen.
- Eg2020May 17, 2020TutorWhen you say updated drivers, which firmware version? The update through the app has not worked for several versions. You have to log in as administrator via a web browser and do a manual firmware update. This got rid of the printer issue for me.
- SurffaJun 18, 2020ApprenticeNow I have been running 2.5.1.16 for quite some time and so far not a single page has been printed out.
Finally. Thanks.
