RichardSlater
Jan 10, 2023Follower
Website that is not secure
I'm working on the firmware updates I've been emailed. However, when I go to www.bestmobilelocksmiths.com/ I get an unsecured website, so I cannot complete the rest of the steps: Click Maintenance > Firmware Upgrade Click Browse and find the file you just downloaded. Click Upload. While the firmware is loading, do not interrupt the upgrade process. Is there a way around this? It didn't matter which browser I used. I tried three different ones.
- Not sure what help to offer other than checking the URL on Virustotal returns a clean result so it’s a legit site with no compromise/malware. However checking it on SSLTest it’s given a B rating as it still supports TLS 1.0, possibly causing your browser or Armor to throw up a warning or error. If you can force your browser to only use TLS 1.2 or higher then it might work.
1 Reply
- JeffgearVirtuosoNot sure what help to offer other than checking the URL on Virustotal returns a clean result so it’s a legit site with no compromise/malware. However checking it on SSLTest it’s given a B rating as it still supports TLS 1.0, possibly causing your browser or Armor to throw up a warning or error. If you can force your browser to only use TLS 1.2 or higher then it might work.
