Dustin_V
May 22, 2019NETGEAR Employee Retired
What is Bitdefender Total Security?
Bitdefender Total Security works against all internet threats – from viruses, worms and Trojans, to ransomware, zero-day exploits, and spyware to keep your data and privacy safe. Included with...
Raymond18521
May 23, 2019Aspirant
NETGEAR Armor™ protects your connected home from Internet threats. Multi-layer cyber security is built into the WiFi router to protect all devices on the home network. Includes Bitdefender® Total Security to provide complete anti-virus and anti-malware protection for all Windows, macOS, Android and iOS devices.
Orbi-Roc
May 24, 2019Luminary
Hi Raymond18521 .Yes, I agree with your post on Netgear Armor. But my question to for Dustin_V still stands. The opening line on the original post states that Bitdefender Total Security is a software installed on the router; and my understanding is that it is not; it is a software installed on specific devices.
- schumakuMay 24, 2019Guru - Experienced User
Orbi-Roc wrote:The opening line on the original post states that Bitdefender Total Security is a software installed on the router; and my understanding is that it is not; it is a software installed on specific devices.
Correct - the information provided is not appropriate. There is some Bitdefender software installed on the router, this is however not the Bitdefender Total Security package - which is intended for the end-point security only.
- Dustin_VMay 24, 2019NETGEAR Employee Retired
Good catch Orbi-Roc. You are correct, Bitdefender Total Security is installed on end devices. Original post has been edited.
