Cayenne08
Mar 31, 2020Guide
Where are Parental Controls and Other Security Features
I just activated Armor started installing the apps on the many mobile devices. I'd have to say the lack of controls and schedules is a huge drawback. Also according to the NETGEAR/ARMOR landing pag...
AbhayB
Mar 31, 2020NETGEAR Employee Retired
Hi,
I am not sure where you see mismatch of advertized features on
https://www.bitdefender.com/site/view/netgear.html and actual applications delivered.
https://www.bitdefender.com/site/view/netgear.html#tsmd_features is the full feature list and it matches what's being delivered.
Please help clarify.
Cayenne08 wrote:
I just activated Armor started installing the apps on the many mobile devices. I'd have to say the lack of controls and schedules is a huge drawback. Also according to the NETGEAR/ARMOR landing page there should be a whole slew of features including parental controls through the armor app but I am barely seeing any features within the app. Before a mod responds with a response saying use Disney circle please read your advertising at the below link:
I feel if we could use the Bitdefender total security app instead it would be the game changer we need. The current apps available are just lacking in features and the product that's being advertised isn't being provided
- Cayenne08Apr 01, 2020GuideNope clearly listed check again. The exact section you selected click mac, iOS or android and you will see parental controls in each section very clearly listed. I've attached screenshots for you as well.
- AbhayBApr 01, 2020NETGEAR Employee Retired
Got it!. We will get it corrected. Of course because NETGEAR already has solution for Parental control using Circle, that's the main reason we cannot have another solution conflict with what's working on router. Other than that, we are working on brining VPN soon to these applications within a month or two.
- Cayenne08Apr 01, 2020GuideI feel having it integrated together with bitdefender (as bitdefender is already capable of doing) makes more sense than that if the disney circle. Personally not having it built in with armor will probably drive me away from the product. Multiple apps and subscriptions for something that should all be controlled from 1 app and 1 subscription makes more sense.
Just my two cents and I am sure more people would subscribe if 1 subscription covered all the features opposed to the current method.
