Cayenne08
Mar 31, 2020Guide
Where are Parental Controls and Other Security Features
I just activated Armor started installing the apps on the many mobile devices. I'd have to say the lack of controls and schedules is a huge drawback. Also according to the NETGEAR/ARMOR landing pag...
Cayenne08
Mar 31, 2020Guide
Nope clearly listed check again. The exact section you selected click mac, iOS or android and you will see parental controls in each section very clearly listed. I've attached screenshots for you as well.
AbhayB
Mar 31, 2020NETGEAR Employee Retired
Got it!. We will get it corrected. Of course because NETGEAR already has solution for Parental control using Circle, that's the main reason we cannot have another solution conflict with what's working on router. Other than that, we are working on brining VPN soon to these applications within a month or two.
- Cayenne08Mar 31, 2020GuideI feel having it integrated together with bitdefender (as bitdefender is already capable of doing) makes more sense than that if the disney circle. Personally not having it built in with armor will probably drive me away from the product. Multiple apps and subscriptions for something that should all be controlled from 1 app and 1 subscription makes more sense.
Just my two cents and I am sure more people would subscribe if 1 subscription covered all the features opposed to the current method.
