LordSirius
May 06, 2022Aspirant
XR1000 & ARMOR VPN
Is there a way for me to upgrade my armor vpn for unlimited data or do I have to download a separate app for their paid vpn services? Asking as the armor app lists the vpn but it is capped at 200mb da...
May 07, 2022Guru - Experienced User
- LordSiriusMay 07, 2022AspirantI attempted to go this route but it seems to not show on android for the upgrade option on the data limits. Anyone have similar experience and any info on a work around? Screenshot attached showing vpn screen from the armor security app on note 20 ultra running Android 12
- LordSiriusMay 09, 2022AspirantSo does anyone have a work around?
- plemansMay 10, 2022Guru - Experienced User
have you tried contacting support on the subscription service?
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
