LordSirius
May 06, 2022Aspirant
XR1000 & ARMOR VPN
Is there a way for me to upgrade my armor vpn for unlimited data or do I have to download a separate app for their paid vpn services? Asking as the armor app lists the vpn but it is capped at 200mb da...
May 07, 2022Guru - Experienced User
LordSirius
May 07, 2022Aspirant
I attempted to go this route but it seems to not show on android for the upgrade option on the data limits. Anyone have similar experience and any info on a work around? Screenshot attached showing vpn screen from the armor security app on note 20 ultra running Android 12
- LordSiriusMay 09, 2022AspirantSo does anyone have a work around?
- plemansMay 10, 2022Guru - Experienced User
have you tried contacting support on the subscription service?
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service- LordSiriusMay 13, 2022AspirantYes, I have tried contacting support and they were unable to assist, directing me to bitdefender, who in turn referred me back to netgear..
