sagjmo
Jan 02, 2018Aspirant
AC1900 Disney Circle Reset Admin Details
Hi, I installed the circle app on my phone with the intent to register it with the netgear router. I was showing my wife, and while I was out of the room, she started the reigstration process to se...
JCECRB
Apr 26, 2018Tutor
Hi
Do you manage to solve this? I have the same issue. Am going round in circles....excuse the awful pun.
sagjmo
Apr 26, 2018Aspirant
Hi there, yes I did manage to solve this, but it wasnt due to help from Circle, or Netgear unfortunately. I just kept going around in circles, literally.
What I had to do was go into my phone and clear the details that were stored against the circle app. I went into setting on my phone as i have a Samsung s7, found the circle app, then went down and selected storage, then pressed clear cache, then did the same to clear data. I was then able to go back into the app and put in the right details on the phone. You obviously will need to make sure you do this on the phone that was originally used to set it up.
I hope this helps you. :-)
- JCECRBApr 27, 2018Tutor
Ah, that's great, glad you sorted it.
I have an iPhone....have deleted the data for the Circle app, reinstalled etc but it is still the same :-(. No idea how to clear the cahce on an iPhone so I will try and restore my phone to a previous version without the Circle app on it. Fingers crossed.
(I have a ticket open with Circle on Netgear support whoc aren't being massively helpful....struggling to get them to see that I can't do all the changes they are asking me to do as I can't get in to change the details without the text code which I can't get because I the phone number is wrong!) Anyway, many thanks for your help, I will persevere.
For reference....for anyone elase who may be having the same problem.
I have sorted it and can now access Circle on my iPhone.
Deleting and restoring the Circle app didn't work
Restoring my iPhone from a previous back up didn't work.
I did multiple hard resets (pressing the button on the back) of the router. Which didn't actually restore the router to factory settings, but that's a seperate issue.....grrrr....and also didn't solve the problem with the Circle app.
Finally I managed to wipe/reset the router to factory settings through the Netgear Genie app (or I guess www.routerlogin.net would work the same) Click on the ADVANCED tab>Adminstration>Backup Settings>ERASE
I also did a hard reset on my modem...The reset button worked just fine for this.
I then reset up the modem and the router from scratch.
Downloaded the Circle app and it let me start the Circle sign up process from the beginning.....including allowing me to put in the correct phone number!
It really was somehting of a palaver but modem, router and Circle now fully operational.
Happy days!
