epsom11
Apr 12, 2020Tutor
Adobe Lightroom not able to verify subscription if desktop added to Circle
Hi - has anyone seen this issue... If I add my desktop as part of "home' or another profile (like myself), make the Filter 'Adult' - I note that Adobe Lightroom (both Classic and CC) are unable t...
Christian_R
Apr 15, 2020NETGEAR Employee Retired
Hi epsom11,
Are you provided a URL that Adobe Lightroom uses to verify subscription? If so, you may need to set the URL to "Allowed" in the customer filter. You may also check your history (located in the profile) and select it as unmanaged.
Christian
