treaders76
Jan 23, 2023Guide
Can no longer access remotely access Circle on my Netgear Orbi router RBR20
Hello,
I can no longer access remotely access Circle on my Netgear Orbi router RBR20. This problem started happening in the last 1-2 weeks. Prior to the last 1-2 weeks I have accessed Circle re...
- Jun 08, 2023
Message from Netgear Support for information:
"...We got some update from Circle team that there are some issue on server side but they are able to fix it now. Please continue to test it for couple more days and confirm if the issue is already resolve."
Mar 21, 2023Guru - Experienced User
For this issues with Circle and Orbi app, please reach out to NG support:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
File a bug report from the Orbi app:
Good Luck
treaders76
Mar 27, 2023Guide
I've now spoken to Netgear customer support twice. They will elevate this issue to Netgear engineering.
Netgear will also liaise with Circle support.
I have previously spoken to Circle support directly. While Circle support did provide some helpful information they also directed me to Netgear support.
- treaders76Mar 27, 2023Guide
Ongoing "Unable to find Circle. What would you like to do next? Try again. Pair new Circle." error message screenshot attached. This is the message I see when trying to connect to Circle remotely. Same error message for ~3 months.
