treaders76
Jan 23, 2023Guide
Can no longer access remotely access Circle on my Netgear Orbi router RBR20
Hello,
I can no longer access remotely access Circle on my Netgear Orbi router RBR20. This problem started happening in the last 1-2 weeks. Prior to the last 1-2 weeks I have accessed Circle re...
- Jun 08, 2023
Message from Netgear Support for information:
"...We got some update from Circle team that there are some issue on server side but they are able to fix it now. Please continue to test it for couple more days and confirm if the issue is already resolve."
wing001
Apr 15, 2023Initiate
I don't think this is a Netgear problem. We have the same issue with a Circle Gen 1 without a Netgear router. It's a Circle app issue. Like everyone else it only started this year and remote access had been fine for years before that. I contacted Circle and after doing all the things requested with no resolution I got the following from Circle support:
"I'll get your case added to our investigation. The investgative team should let you know as updates are made available."
treaders
Apr 15, 2023Star
Wow! No wonder Circle says, “we’ll talk to Netgear” and Netgear says, “we’ll talk to Circle”… 👈👉
I’m still waiting on a response from Netgear after they elevated this issue to their engineering/technical team and for them to talk to Circle. This was several weeks ago.
- coupeborgwardApr 16, 2023Tutor
Same here. My ticket was elevated and haven't heard anything from them since. It seems there is not much interest to fix this issue at all
- treadersMay 04, 2023Star
Netgear called back today Fri 5 May. Netgear engineering wanted to know if I have blocked port 443 on my router. I have not. I have not customised the Orbi router in any way. They also asked if my internet service provider, Vodafone Australia, may have blocked port 443. I am not aware of Vodafone Australia doing this.
- MattMacknamaraMay 04, 2023StarNope. I’m with Telstra for mobile and I can’t imagine they did that either.
I’ve also made no custom changes to the modem or router.
Definitely an issue at their end.
