treaders76
Jan 23, 2023Guide
Can no longer access remotely access Circle on my Netgear Orbi router RBR20
Hello,
I can no longer access remotely access Circle on my Netgear Orbi router RBR20. This problem started happening in the last 1-2 weeks. Prior to the last 1-2 weeks I have accessed Circle re...
- Jun 09, 2023
Message from Netgear Support for information:
"...We got some update from Circle team that there are some issue on server side but they are able to fix it now. Please continue to test it for couple more days and confirm if the issue is already resolve."
NateT
Jun 07, 2023Tutor
How about your Orbi firmware, are you both on the same release?
treaders76
Jun 07, 2023Guide
Could be the Orbi firmware. I'm running V2.7.4.24. Manually updated a few months ago.
NateT, I see you're running firmware V2.7.5.4 on your Orbi and satellite.
- NateTJun 07, 2023TutorYeah I'm running that on my Orbi RBR50. I had to manually update that as well. If you have an Orbi 20 it might be a different release though. Definitely worth checking out. Wondering what firmware others have that it's now working for as well?
- treadersJun 07, 2023Star
Thanks NateT. I'm running the following:
Router RBR20 V2.7.4.24
Satellite RBS20 Orbi V2.7.4.24
Satellite RBS40 Orbi V2.7.4.24I'll investigate what latest firmware version is for the RBR20, RBS20 and RBS40.
Hmm, I'm running the latest firmware... đ
RBS20 Firmware Version 2.7.4.24
https://www.netgear.com/support/product/rbs20#downloadRBS40 Firmware Version 2.7.4.24
https://www.netgear.com/support/product/rbs40#download - coupeborgwardJun 07, 2023Tutor
Yep I'm running the latest firmware on my RBR20 as well -> 2.7.4.24
