kimmiess
May 20, 2021Tutor
Cannot connect to circle
I cannot connect to circle on my iPad or my android phone. I rebooted Orbi and now the circle app is wanting me to reset everything up, but on the iPad it won't go past telling me that i can enable a...
May 21, 2021Guru - Experienced User
Try removing the Circle app from the devices then re-install it.
Is Circle or Parental Controls enabled on the router?
What FW version are you using on Orbi?
