mckmck
Jun 08, 2020Aspirant
Cannot turn on Circle
Cannot turn on Circle I have not been able to turn on Circle for my router. If I login via the Nighthawk app, there is no parental controls option. If I login via the computer, the Parental Controls ...
- Jun 09, 2020
With enough poking around, I found the solution to my problem. The AP mode had been turned on in the advanced settings for some reason. As soon as I turned this back to router mode, I was able to turn Circle back on. All is working fine now. Steps below in case you have a similiar issue.
- Logon to routerlogin.net
- Go to Advanced tab -> Advanced Setup -> Router/AP/Bridge/Repeating Mode
- Make sure AP mode is not selected (Parental Controls including Circle are not supported in AP mode)
Picture attached to show where this is found.
mckmck
Jun 09, 2020Aspirant
- Christian_RJun 11, 2020NETGEAR Employee Retired
Hi mckmck,
Thanks for sharing your experience as it may help others who may experience the same issue.
Christian
