mckmck's avatar
mckmck
Cannot turn on Circle
Cannot turn on Circle I have not been able to turn on Circle for my router. If I login via the Nighthawk app, there is no parental controls option. If I login via the computer, the Parental Controls ...
  • mckmck's avatar
    Jun 09, 2020
    With enough poking around, I found the solution to my problem.  The AP mode had been turned on in the advanced settings for some reason.  As soon as I turned this back to router mode, I was able to turn Circle back on.  All is working fine now.  Steps below in case you have a similiar issue.
    1. Logon to routerlogin.net
    2. Go to Advanced tab -> Advanced Setup -> Router/AP/Bridge/Repeating Mode
    3. Make sure AP mode is not selected (Parental Controls including Circle are not supported in AP mode)
    Picture attached to show where this is found.
