Concerned-user's avatar
Jun 03, 2021
Can't connect to circle while creating account after R7000 factory reset
I updated router firmware to "1.0.11.123 Hot Fix for R7000", did factory reset, then restored the router's saved configuration.   Now, the Android "Circle 1st Generation" app displays "Unable to fi...
  • Concerned-user's avatar
    Concerned-user
    Jun 12, 2021
    I have resolved my issue by going to Android settings, finding the application Circle 1st gen -> storage & cache -> clear cache and clear storage.
