mc510
May 29, 2019Guide
Can't create account to use Circle
Trying to get Circle going on my R7000. I enabled it on my router, then downloaded the Circle app on my Android device ... app says my router is compatible, I use the app to log in to my router accou...
mc510
Jun 07, 2019Guide
Hi again, sorry it took me a while to find the time to do the reset/reconfigure. I did it yesterday, but am still having the same problem with the Circle app (Android) saying that it can't connect to Circle.
- DexterJBJun 09, 2019NETGEAR Moderator
- mc510Jun 10, 2019GuideI’m feeling kind of stupid here, but I can’t find where I am supposed to enable private messages. (Currently using iOS Safari mobile browser, if that matters)
- DexterJBJun 10, 2019NETGEAR Moderator
Hi mc510, you can click on your profile and go to My Settings > Preferences > Private Messenger > Check Turn on private messages.
Dexter
- mc510Jun 11, 2019Guide
found it. PM now activated.
