DBVicAU
Apr 10, 2021Tutor
Circle - "something went wrong" (RBR40)
Hi It would appear that since 2.6.2.140 firmware update on my RBR40, Circle has stopped working. I can disable it on the router and enable it via the app - it then shows as enabled on the route...
DBVicAU
Apr 15, 2021Tutor
Thanks Christian
I did try the older firmware, no luck.
Netgear has also called me and spent ~2 hours trying to resolve the issue without any luck. It may be their firmware has not been working corectly with some models of router for a while. They're going to come back to me with a potentially beta / early release of firmware to test.
Thanks again
DB
Christian_R
Apr 21, 2021NETGEAR Employee Retired
Hi DB,
Thanks for the update! Has our support team been able to follow up with you?
Christian
- DBVicAUApr 22, 2021Tutor
Hi Christian
Thanks for the follow up.
I was sent a beta firmware, but it appears to be for the wrong build of software so I've questioned this and am awaiting a response.\I will update here once I have it and have been able to test it.
Thanks
Darren
