Concerned-user
Jan 09, 2021Guide
Circle 1st Gen on R7000 blocks sites on 1st attempt, NETGEAR holds a solution that Circle gave them
I have a problem with free "Circle 1st Generation" embedded on my NETGEAR R7000. The router has the most recent firmware version V1.0.11.110_10.2.100 published on 9/20/2020 at https://www.netgear.com...
Christian_R
Jan 14, 2021NETGEAR Employee Retired
Hello,
Welcome to the community! I'll check in with our product teams and provide an update as soon as possible.
Christian
Concerned-user
May 20, 2021Guide
Five months passed, I still don't have a solution. My NETGEAR Support Case # 44001765. Am I alone waiting almost half a year for a resolution of a suppport ticket?
Still have the same symptoms: Website is blocked for the first try accessing it even it is not blocked on the filtered profile. Then after a minute or two the page will load normally. There are no traces in the "filtered" section of Circle history. Very frustrating.
