Atlixnor
Oct 07, 2021Guide
Circle 1st gen on RBR50 V. 2.7.3.22 question
Hi, just wondering if it is worth trying enabling Circle again? I bought this mesh system mainly because of the Circle feature, but had to remove circle and factory resert the router, becaus ecircle ...
- Oct 15, 2021
If a factory reset is needed you can just load the backup from file and be up and running with out having to re-configure everything.
Atlixnor
Oct 15, 2021Guide
ok. But why do I need a backup of the config after enabling circle? I have enabled it now, and as last time I got a problem with a Home profile device (PS4), but I moved it tio "Unmanaged" and then it worked.
By the way, what is the difference between:
-Remove it from Home
-Unmanaged
-Remove from Circle
- FURRYe38Oct 15, 2021Guru - Experienced User
