Apacolypse
Sep 24, 2023Follower
Circle admin password reset
Hi I have just redownloaded Circle and I am the only admin but no SMS is being sent to my number. I see older articles about messaging an employee from 2-3 years back. Is that the only way to fix my i...
Sep 24, 2023Guru - Experienced User
- Bin888Sep 30, 2023Aspirant
Hi FURRYe38,
The link that you have posted took me to a normal rootcause analysis page which I can also find using google search, it's not super helpful.
I have done every steps including uninstalling Circle app, enable and reenable parental control locally and retry, nothing works.
In my opinion, this is such a simple thing why make it so hard to get a 4 digit code for a parent? Every app that I have used, have the option to reset password in like 1 minute.
On the link that you have provided, it says the last resort is to factory reset the entire router, and then I think I need to END my Subscription to Circle. And then reset up the router again with SSID and password, and reenable parental control (circle) from there and resubscribe. Personally, I think this is a very damaging method to get a 4 digit code.
I am sure there's a simpler method to retrieve the code from the router itself, can we not contact Netgear support to pull it out from the backend?
- FURRYe38Oct 03, 2023Guru - Experienced User
You'll need to contact NG support for there help. This is beyond forum help.
