dbriankessler
Jul 14, 2023Tutor
Circle blocking internet, but I don’t have circle anymore
I don’t know where to ask this as I’m not a frequent flier here. For background info, I used to have Circle embedded in my Orbi. I upgraded to a newer model Orbi and no longer have or use Circle. I’m ...
dbriankessler
Jul 18, 2023Tutor
Thanks for the reply. I’m not sure why this happened, but after speaking with a friend, this seems to be common with the device I was trying to update online. I switched from my home WiFi to a mobile hotspot and got it connected. After one basic update (it’s a tool that has multiple module updates frequently), I went back to my home WiFi without issue. I still have no idea why Circle kept popping up though. We have t used or even had access to Circle for months. To answer your questions though, we don’t have Circle installed anywhere on any device. Our Orbi base is the RBR850 with multiple satellites.
Jul 18, 2023Guru - Experienced User
Well Circle is not supported on Orbi 8 series systems. Smart Parental Controls is.
Seems like it worked it self out.
