kristib
Jun 03, 2020Tutor
Circle Blocking Known Sites
My household uses the free Circle program. Around a month or two ago, Circle started randomly blocking sites we've visiting many times before and/or sites that do not fit any sort of blocked category...
Christian_R
Jun 05, 2020NETGEAR Employee Retired
Hello kristib,
Welcome to the community! May you provide us with the router model and firmware version your router is currently on.
Christian
- ptweav75Jun 07, 2020Initiate
My circle filters/blocks most websites too. Under history, I do not see the sites to "allow" them. I have to set filter to "none" or disable circle to use internet. Firmware V2.3.5.12_1.0.8
- kristibJun 11, 2020Tutor
Thanks. Model: R7000/AC1900. Firmware Version V1.0.11.100_10.2.100.
- bwilfordNov 05, 2020TutorI have the same issue. It has occurred off and on and usually clears with a router reboot. However I’ve rebooted a few times in the last week and can’t get rid of the problem, other than turning Circle off. I’ve also found if I try the same site several times it may work eventually. By no means valid solutions, but hopefully the extra info can help someone fix the issue.
- jasonsfNov 06, 2020TutorI am also having this issue. R6700v3 firmware v1.0.4.102_10.0.75
