kristib
Jun 03, 2020Tutor
Circle Blocking Known Sites
My household uses the free Circle program. Around a month or two ago, Circle started randomly blocking sites we've visiting many times before and/or sites that do not fit any sort of blocked category...
Christian_R
Jun 05, 2020NETGEAR Employee Retired
Hello kristib,
Welcome to the community! May you provide us with the router model and firmware version your router is currently on.
Christian
kristib
Jun 11, 2020Tutor
Thanks. Model: R7000/AC1900. Firmware Version V1.0.11.100_10.2.100.
- bwilfordNov 05, 2020TutorI have the same issue. It has occurred off and on and usually clears with a router reboot. However I’ve rebooted a few times in the last week and can’t get rid of the problem, other than turning Circle off. I’ve also found if I try the same site several times it may work eventually. By no means valid solutions, but hopefully the extra info can help someone fix the issue.
- jasonsfNov 06, 2020TutorI am also having this issue. R6700v3 firmware v1.0.4.102_10.0.75
