kristib
Jun 03, 2020Tutor
Circle Blocking Known Sites
My household uses the free Circle program. Around a month or two ago, Circle started randomly blocking sites we've visiting many times before and/or sites that do not fit any sort of blocked category...
kristib
Jun 11, 2020Tutor
Thanks. Model: R7000/AC1900. Firmware Version V1.0.11.100_10.2.100.
bwilford
Nov 05, 2020Tutor
I have the same issue. It has occurred off and on and usually clears with a router reboot. However I’ve rebooted a few times in the last week and can’t get rid of the problem, other than turning Circle off. I’ve also found if I try the same site several times it may work eventually. By no means valid solutions, but hopefully the extra info can help someone fix the issue.
