Torque1
May 23, 2021Aspirant
Circle breaks WiFi calling
When circle is enabled, and the profile assigned to a device is not none, WiFi calling does not work. It simply won’t connect. This is tested using a UK three and UK O2 SIM card. If the Circle profile...
Christian_R
May 26, 2021NETGEAR Employee Retired
Hello Torque1,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- Torque1May 27, 2021AspirantI purchased the device last November so it’s outside the support period. It has had the issue since new, but I didn’t realise it was circle causing it until I found time to properly diagnose.
- ManxvikingAug 25, 2021Tutor
i have had a similar issue. Spent weeks trying to understand why wifi calling only works intermittently, often having to wait several hours for the iphone SE to pickup wifi calling despite it being connected to a strong signal. Disabled Circle and it connects immediately. The circle profile had VPN etc enabled. It seems that this is a known issue for sometime but Netgear has yet to address it. The whole point of having the orbi was for the parental controls. Come on Netgear, sort this out.
- FURRYe38Aug 25, 2021Guru - Experienced User
