Teacup
Oct 24, 2019Aspirant
Circle causing internet outages
I previously had a Netgear router and used Circle with Disney successfully with it. Last month I just got a new one (R7610) and since then Circle is acting up. Internet is turned off at random and I ...
DexterJB
Oct 24, 2019NETGEAR Moderator
Hi Teacup, welcome to the community! To confirm, the model number of the device is R7610, correct? What is the firmware version of the router? Are you using a separate Circle hardware or the built in Circle functionality of the router?
Dexter
Teacup
Hi Dexter
Thanks for taking the time to reply. The Netgear router is V7610 (also goes by the name Gateway Pro), it was supplied by our telco company when we upgraded our internet connection. The firmware version is V2.2.2.28. We are using a separate, stand alone Circle. There is no parental control on the V7610 router.
