Teacup
Oct 24, 2019Aspirant
Circle causing internet outages
I previously had a Netgear router and used Circle with Disney successfully with it. Last month I just got a new one (R7610) and since then Circle is acting up. Internet is turned off at random and I ...
DexterJB
Oct 24, 2019NETGEAR Moderator
Hi Teacup, welcome to the community! To confirm, the model number of the device is R7610, correct? What is the firmware version of the router? Are you using a separate Circle hardware or the built in Circle functionality of the router?
Dexter
DexterJB
Hi Teacup, thanks for responding. It is best that you check with your ISP since the V7610 has a custom firmware developed with them and is different from the retail devices. They should be able to provide support for it. You can check for any compatibility issues that they may have with the Circle hardware.
Dexter
