PIerreSc
Jun 08, 2022Aspirant
Circle Certificate seems to have expired
Hi, I've struggling with connectivity issues in my home for the past few days. I have been rebooting my router few times, reinstalled things, no changes. Turns out, I noticed I could no longer go ...
PIerreSc
Hi,
Here you go !
KevinLiT
Jun 08, 2022NETGEAR Moderator
Hello PIerreSc,
Welcome to the NETGEAR Community!!!
I understand you are having issues connecting to your admin page when your Circle features are enabled.
On your Circle app please ensure the following:
- Check to make sure your profile isn't Paused or in a Focus Time, or Bedtime. Open the Circle app and the profile your device is assigned to check for each of those. Disable to test if that was what caused the connection problem.
- Look at this History >> Filtered section for the profile. If the website or app traffic you wanted to load appears there you may need to change your Filter Settings, Filter Level, or make a Custom Filter to allow that.
- Misidentified devices assigned to the wrong profile may be filtered in a way you didn't intend. Check that your device is identified correctly and on the right profile: Identifying and assigning your family's devices with Circle.
For more information about the Circle Security warnings please navigate to the link below:
Best,
Kevin
Community Team
