Sacul210
Apr 10, 2023Aspirant
Circle change phone number
I cannot change the phone number to my Circle account because it is trying to send the code to my old cellphone. Anyway to change my phone number? Any help will be much appreciated. Thanks Luis
saadali
To change the phone number associated with your Circle account, you will need to follow the steps provided by Circle. Typically, you will need to log in to your account, go to your account settings, and update your phone number information. If you are unable to access your old phone number to receive the verification code, you may need to contact Circle customer support for further assistance. They may be able to help you verify your identity and update your phone number manually.
- Sacul210Apr 11, 2023AspirantI appreciate the information, but I do not have access to my old phone number. I will definitely call customer service. Thanks anyways.
