MatinicusRock
May 21, 2020Star
Circle Compatibility with New Orbi Wifi6 AX-6000
Hi there, Has anyone been able to pair a Circle Disney 1st Gen box with the new Orbi AX6000? I've connected my 1st gen Circle to the RBK852, and if I try to add any kind of filter from adul...
jjpank
Jun 22, 2020Tutor
Did you find anything out on your question? I have the same problem. I just bought the RBK752 (AX4200) and I cannot use my Circle 1st gen filters without it completely shutting down the entire internet to that device. I would HOPE they would have circle included within these expensive wifi routers, when I researched to purchase it, it was misleading and made it look like it was already included.
