MatinicusRock
May 21, 2020Star
Circle Compatibility with New Orbi Wifi6 AX-6000
Hi there, Has anyone been able to pair a Circle Disney 1st Gen box with the new Orbi AX6000? I've connected my 1st gen Circle to the RBK852, and if I try to add any kind of filter from adul...
jjpank
Jun 22, 2020Tutor
Did you find anything out on your question? I have the same problem. I just bought the RBK752 (AX4200) and I cannot use my Circle 1st gen filters without it completely shutting down the entire internet to that device. I would HOPE they would have circle included within these expensive wifi routers, when I researched to purchase it, it was misleading and made it look like it was already included.
Scott2997
Jul 03, 2020Aspirant
Mark me down as someone with the same issue. Just bought the Orbi AX4200 set from Costco. My 1st gen Circle blocks everything with any filtering profile as well. Everyone is unfiltered for now until there’s a fix. Hope it’s soon!
