strayfrog
Mar 17, 2020Tutor
Circle connectivity interruption on RBR50
Hello -- I'm running into intermittant disconnection issues with Circle. This started about a week ago. I decided to upgrade my RBR50 to the latest firmware (V2.5.1.8) to see if things would improve ...
Retired_Member
Apr 07, 2020This is the same when we contacted the Priority Netgear Support, it used to take them 1-3 days to get back to us, now they take up to 7 days just to reply our message without a good solution.
Christian_R
Apr 08, 2020NETGEAR Employee Retired
Hi AlexWong,
All previous firmware versions for the Orbi should work with Circle. Our product teams are currently investigating reports of Circle possibly causing intermittent disconnections. We currently do not have an ETA or further details at this moment.
Thank you for your patience,
Christian
- herman2pApr 15, 2020Aspirant
Christian,
I recently purchased the RBR50 and am running the latest firmware. My first NETGEAR product in over a decade. The system worked for about 2 or 3 days, then started to disconnect from the internet a couple of times a day. Disconnecting "circle" seems to have solved this issue, but with 3 teenage boys it has created another problem. Unfortunately, I am going to be returning this item as soon as I identify a replacement.
- strayfrogMay 17, 2020TutorHello — can you provide any update if the circle issue has been root caused? Can we expect a fix anytime soon?
Thanks.
