mcornell
Jun 14, 2019Aspirant
Circle Continually loses connection/settings Orbi
We have been using the Disney Circle product enabled in the RBR50. We have noticed the following behavior Circle loses its connection Once it resestablishes connection, all settings are purged...
DexterJB
Jun 17, 2019NETGEAR Moderator
- KraftjcJun 25, 2019AspirantI am having the same problem. Did you get resolution?
- mcornellJun 26, 2019Aspirant
I haven't been away from my Orbi for a week and a half, however, before I left, a contact with Circle suggested that I needed to move any and all smart home devices to an unmanaged setting. This is different from leaving them in the default Home setting.
This will get put to the test over the next few days and weekend to see if this has an impact.
- Fmag69Oct 16, 2019AspirantI am having the same issue. Very annoying.
- DexterJBOct 17, 2019NETGEAR Moderator
Hi Fmag69, welcome to the community! Were you able to try the suggested steps posted above? And what other steps have you tried so far?
Dexter
- Fmag69Oct 17, 2019Aspirant
Yes, I kmoved everything to unmanaged last night. This morning the Circle was not connected again.
