mcornell
Jun 14, 2019Aspirant
Circle Continually loses connection/settings Orbi
We have been using the Disney Circle product enabled in the RBR50. We have noticed the following behavior Circle loses its connection Once it resestablishes connection, all settings are purged...
VKreugel
May 08, 2020Initiate
I have been having the same problem. I have “enabled” Circle Parental Control both on my app (by moving the switch) and on the webbrowser and still every morning I get a message from Circle connection has been lost. So bedtime does not run (as time of loss of connections is mostly an hour to half an hour before bedtime is due).
It is very annoying, as one of the reasons I bought Orbi was to be able to program to switch off WiFi for my kids’ devices...
Any solution?
Any solution?
- FiveironMay 08, 2020Tutor
Unfortunately no. I've been "escalated" to level 2 engineering for the past 5 months and the only responses I get from Netgear is to disable Circle because it's garbage. I've demanded my money back but was told they've given me a "solution". 300 bucks wasted. I will never again buy anything made by Netgear, complete garbage.
- PiupolinoMay 17, 2020Guide
Another one joining the group with the same Orbi problems described in this group and a usefull (and expensive) Netgear support.
- PSUHammerMay 18, 2020Luminary
It seemed to be working fine for me until the 2.5.1.8 firmware then something broke that started kiling Internet connectivity to the router itself instead of specifc devices configured in Circle. I understand that Circle uses ARP spoofing which may be now misconfigured or causing issue with Netgear's capabilities as of a recent firmware.
