mcornell
Jun 14, 2019Aspirant
Circle Continually loses connection/settings Orbi
We have been using the Disney Circle product enabled in the RBR50. We have noticed the following behavior Circle loses its connection Once it resestablishes connection, all settings are purged...
Fiveiron
May 08, 2020Tutor
Unfortunately no. I've been "escalated" to level 2 engineering for the past 5 months and the only responses I get from Netgear is to disable Circle because it's garbage. I've demanded my money back but was told they've given me a "solution". 300 bucks wasted. I will never again buy anything made by Netgear, complete garbage.
Piupolino
May 17, 2020Guide
Another one joining the group with the same Orbi problems described in this group and a usefull (and expensive) Netgear support.
- PSUHammerMay 18, 2020Luminary
It seemed to be working fine for me until the 2.5.1.8 firmware then something broke that started kiling Internet connectivity to the router itself instead of specifc devices configured in Circle. I understand that Circle uses ARP spoofing which may be now misconfigured or causing issue with Netgear's capabilities as of a recent firmware.
