rich_benson
May 14, 2023Aspirant
Circle down
Been using Parental Controls (on Netgear) for years, and had trouble with stable network connections (and certificate issues (Circles technique for controlling traffic) the last few days. After disab...
- May 15, 2023
The mobile app is the only way to control Armor or SPC now days.
May 14, 2023Guru - Experienced User
Probably Circle is going away. Have you tright the Nighthawk moble app to see if SPC is available there?
rich_benson
I remove the nighthawk mobile app sometime ago. I will give that a try.
- FURRYe38May 15, 2023Guru - Experienced User
