DougB628
Apr 12, 2019Apprentice
Circle filtering unmanaged device
I have been testing Circle on my Orbi, and I am finding that it is filtering unmanaged devices. I have attached a screen shot of the filter page that comes up, which clearly indicates that the device...
DexterJB
Apr 14, 2019NETGEAR Moderator
Retired_Member
Apr 22, 2019Same problem here. Is there a fix for this?
- DexterJBApr 23, 2019NETGEAR Moderator
Hi Retired_Member,
Welcome to the community!
Please make sure that your router is using the latest firmware if you haven't updated it yet. What model is that by the way?
Dexter
- Retired_MemberApr 30, 2019
Thank you DexterJB
I have the latest firmware 2.3.1.48.
The problem is:
Internet browsing history for a number of unmanged device appears in random wrong profiles. I can see that obviouse web-url from "electric car charger" is in my Kids profile. I have tried to make a "dummy" profile and add the unmanaged devices there but no luck.
Arild
- DexterJBApr 30, 2019NETGEAR Moderator
Hi arildj, thanks for the update. You can try resetting the device to factory settings and check if the issue will persist. Let me know how that works.
Dexter
