dtay
Aug 17, 2022Luminary
Circle Home Plus/v2 with Orbi AX6000 (RBK85xx) compatibility issues resolved?
Has Netgear resolved the compatibility issues with using Circle v2/Plus (2nd gen)? I know earlier on, there were numerous issues encountered from compatibility to performance and it got to the point ...
- Aug 18, 2022
Hello dtay ,
Thank you for your post!
Circle is not supported by Orbi AX.
However, the Circle Home Plus can be used with the RBR850 in compatibility mode.
For more information on Circle supported devices please navigate to the link below:
https://kb.netgear.com/000044718/Which-NETGEAR-routers-support-Circle-Smart-Parental-Controls
For more information on Circle Home Plus compatibility mode for RBR850 integration please navigate to the link below:
https://support.meetcircle.com/hc/en-us/articles/360028507711
Best,
Kevin
Community Team
KevinLiT
Aug 18, 2022NETGEAR Moderator
Hello dtay ,
Best,
Kevin
Community Team
dtay
Aug 18, 2022Luminary
Hi Kevin,
Thanks for the update. I am running Circle Home Plus v2 (the 2nd gen product) but it's distressing to hear that it will only work in compatibility mode, which severely limits or impacts the performance of the router. đ
