Ravipati
Nov 08, 2021Aspirant
Circle netgear has stopped blocking the YouTube
Hi Team, I am not able to block youtube using Circle 1st Gen in my router R8000P. it used to work previously but now it is stopped work. Please let me any suggestions. thanks & Regards, Ravi...
- Nov 21, 2021
Thanks for providing the info. We recommend leaving the IPv6 option off unless your ISP configuration requires you to do so.
Dexter
DexterJB
Nov 16, 2021NETGEAR Moderator
Hi Ravipati, we'd like to know the following:
What is the firmware version of the R8000P?
Are you encountering any error? If yes, please provide a screenshot if possible.
Does the issue persist when trying it on another device?
Dexter
Ravipati
Nov 18, 2021Aspirant
Hi DexterJB
Firmware version is: V1.4.2.84_1.3.42
This problem occur only if I enable IPV6. Some of the sites are not blocked by 1st Circle if IPV6 enabled. When I disable IPV6, everything working find.
Thanks & Regards
Ravipati
- DexterJBNov 21, 2021NETGEAR Moderator
Dexter
