KKE55's avatar
KKE55
Guide
Dec 24, 2019
Circle netgear not blocking YouTube
Hello,
Circle netgear has stopped blocking the You Tube App on my Apple TV in the last few days. Anyone has the same problem? Or know a solution?
Thanks!
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi KKE55, welcome to the community! Does the issue persist on your other devices as well? Have you tried moving the Apple TV to another profile or a new one with a similar restriction?
    Dexter
    • KKE55's avatar
      KKE55
      Guide
      Hi Dexter. Yes it happens on other profiles (with a Mac or an iPad). In my case Circle has completely lost the ability to block YouTube.
      Thanks for your help.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi KKE55, I have sent you a message. Please check your inbox.
      Dexter
