pbittle
Aug 27, 2019Tutor
Circle Netgear on Orbi RBK50 Lost its internet connection
I am frequently getting the "Circle lost its Internet connection", yet all the devices on the network are still just chugging along just fine with no interruption to what they're doing. It will often...
carimina
Aug 29, 2019Tutor
I have this same issue all the time. I receive a notification that Circle has gone offline but everyone can still access the internet. I upgraded the firmware on the Orbi and I even started my Circle setup all over from scratch (which is annoying because everyone and everything that ever had access to my Wifi, it notifies me that they have joined again). The other responses I read say to disable it all together but I like how it works and I pay for the premium portion of it to manage Circle Go. Is there a known fix for this anywhere?
pbittle
Aug 31, 2019Tutor
I understand. We bought this Orbi system because we were having the same sort of problems with a Nighthawk X6. I thought it might just be getting tired. But $300 later, it's as bad, if not worse, but with better wifi coverage across the house. :smileywink:
My wife is starting an online Master's program and was having weird issues on her laptop. Turns out Circle was kind of half blocking things like some images, but not all, even within the same discussion thread and web site. Once I changed her device assignment to "Unmanaged" all those issues went away. Obviously, that is not an option for my daughter's phone.
A co-worker who now uses the Circle app on his Orbi, at my recommendation, says he gets the same odd disconnect/reconnect message, but sees no real effect on his or his family's internet access.
I realize that part of the message has to do with whether the Circle application in the Orbi can "phone home" or not, but that should be a different message. Nonetheless, it is also blocking things without any sort of indication that it is, nor even in its logs.
OK, one last weird behavior we've seen, is that if YouTube "restricted mode" is engaged you can't access any YouTube channels, and just random videos don't work. My wife will sometimes watch makeup tutorials, and the channel access, and some individual videos will not appear until we turn the restricted mode off for YouTube.
With all this having been said, however, Circle is still the best system I've used so far! I've tried Norton, Kaspersky, and several others over the last while, all of them fell far short of Circle's ability, either over-restrictive or under. What they're trying to do is hit a moving target, at best, and they do a pretty good job overall!
